What version of the system are you on ... it should be 5.9.902.
I am in a 3G area and twice went through a two-week period where I would just loose 3G. It would be out for a while and then come back. This happened and happened and happened. After two weeks of this it suddenly stopped as abruptly as it had started.
I concluded hat they were working on the tower that was servicing my area.
Noone at Verizon knew anything about it when I asked.
There are other classical data drop issues. If they swapped the phone did they give you a new SIM card. If no, get a replacement SIM card installed.
... Thom
The verison of my phone is 5.9.904
Is updating your PRL an option (dialing *228), or is that still frying SIMs?
I thought you were joking, really.(I can think of two cases discussed here where it was an inconsistency between the Bionic and the user's body chemistry).
... Thom
