So something is going on, but not sure what exactly.
Background first: 2.1 Leak v3, no new apps, updates, setting changes for about a week, conservative use of task killer (start-up, heavy app use only), always have had 2 or 3 bars with 3G. Battery usage screen shows all typical usages.
At work today, and noticed the battery was draining really fast. Over the day, I'll usually use 20 to 30%, at the end of shift I used 75% and this was with lighter-than-normal use.
Killed some apps to see if there something abnormal going on in the background, nothing though. There wasn't the 50% signal issue (fixed that at last start-up). Have been up running ~98 hours total. No "awake" problems.
The only thing I saw was that 3G rarely displayed, and when it did I would get no bars and no Tx/Rx arrows. Phone almost always displayed 1x instead, data (through the brower) was slower than normal then.
I tried a restart, roaming list update, and programming/activation update (*228 1 and 2); none of this helped any.
Tried searching the forums, but the keyword search will not accept "3G" and if I put in something like "3G issue" it drops the 3G and only searches for "issue." "3G" is considered too short, doesn't allow as a tag either.
Any help very appreciated. Only guess I have is that part of the radio/antenna hardware is broken or my battery 'sensor' is off (both the top bar and widget are displaying roughly the same usage)
