Help 3g issues?
droid51378
Is anyone else having issues with 3g? Mine goes in and out,but this morning I lost it completely and could not get it back & tried factory reset, battery pulls, airplane mode & signal refreshers. I was on day 15 today and got thego ahead from verizon to return it, but before that, they installed a new Sim card & that resolved the issue... Or they thought it did. Worked fine for a few hours, but it just went out again and I had to battery pull to regain 3g.
Anyone else experience anything similar?
Im located in southern California and i rarely lose 4g, amd then for maybe at the most I am on 3g for about a minute maximum.
Call VZW Tech support if your havimg this much of an issue, might be your location.
Yup, same problems. I loose the 3G connection often and have to go to 4G. I don't need 4G all the time so I don't use it. Would be nice to have 3G work right.
1st phone had no 3g after 2 days, tech support tried to help, but then the phone would not to a factory reset, they told me to exchange it.
