Help 3G not working after ICS downgrade
cdamy
Hi guys. I live in Greece and I have a beautiful Samsung SII GT-i9100 which I bought online and did not receive with any strings attached. About 2 motnhs ago I upgraded to ICS; it looked like a logical decision at the time, but it went south pretty fast.
The phone ate away at the battery and it lagged horrendously, something my 2-core phone never did before. Very often it would hang needing a hard restart (take out battery) or even restart itself. I spent about a month trying to cope and because I didn't know how to reverse it.
But I coulldn't cope any more so I decided to downgrade (but not to ROOT, I'm still in unsure whether I understand enough). I read up on it and it soon became clear it was doable.
The hard part was getting the right ROMs (and it still is). I looked for 'the right' kind of Gingerbread but to no avail; most links were either dead or a trap (admiralackbar . jpg). Finally I struck on some promising ROMs (3 in number, of which 2 work for me).
I used Odin3_v1.3 and flashed my phone with:
1. GT-I9100_INU_I9100XWKL1_I9100ODDKL1_I9100DDKL1.tar.md5, and
2. GT-I9100_ORS_I9100XWKJ1_I9100OXXKJ1_I9100XXKI4.tar.md5 .
Both worked fine and I thank my lucky stars my phone is up and running again, just like before.
Only thing I can't seem to resolve is that 3G/GPRS stopped working. I called the phone company (WIND HELLAS S.A.) and they said that everything was OK on their part.
I tick the 'User Packet Data' box which used to bring up the 3G/GPRS icon (sooner or later) and provided said conectivity. Now, nothing. Any ideas or opinions more then welcome. Also questions!
Could be some app blocking it?
tl;dr
Downgraded Galaxy SII form ICS to Gingerbread and now 3g/GPRS won't work. Halp!
Did you clear data with a factory reset after flashing the new firmware?
If not, there could be something from ICS left behind which is affecting connectivity.
Yes, I did it at least twice, though not sure with what order, so your suggestion may have merrit.
I will back-up, reset, flash and report back on Monday most likely.
Thx, I feel a glimmer of hope already! :)
So, I'm back with news and apologies for being later than I promised.
I reset to factory default twice and I found these two facts out:
  1. I've installed a Danish version (though I can switch to any language afterwards - I thank my Germsn for that!) and
  2. GPRS works after the reset up until I switch on WIFI and connect to a network, afterwards I cannot make come on by any means.
Any opinions or suggestions?:confused:
It was the IPNs!!!1!
For G*D knows what reson the software deleted the Provider's APNs after first run and 3G/GPRS configuration became untenable.
All I had to do was restore the defaults.
Yatta!:D
