Help 3G not working
reventon
Yesterday i got a new sim card. Since then the 3G symbol is not showing up next to the signal bars. Wifi works ok but when i disable wifi, 3G is not coming up
I used apndroid. but it doesn't help either. In that it says 3G/Edge/Gprs is active but still can't get the symbol and even the websites are not opening. i tried uninstalling apndroid app and restart the phone. still no luck with or without this app.
if i try to open a website it says not connected to internet.
what wrong could i have done? please advice.
thank you
Call AT&T. They're probably going to have to be the ones to sort this out for you.
I called them. They told to wait 2-3 hours after they made me restart my phone 2-3 times. Didn't work.
Manually entered APN info and voila it started working. Had uninstalled APNDroid, probably it wiped APN too. Reinstalled APNDroid and entered apn info and it worked.
Thanks
