Help 3G or wifi?
VZdubrep
Hey guys....I'm curious what uses more better? Using the 3g or WiFi? Thanks in advance guys! I did some searching and I didn't see a thread adking this question.....
I'm not sure what you're asking. If you're asking which is better, WiFi wins HANDS DOWN. It's WAY faster.
If you're asking which uses more battery power... if you have a solid WiFi connection and your 3G is sniffing... I'd say the 3G is using more power, and vice versa. I have WiFi turned off unless I'm actually using it.
