I'm on 2.1 nordic on vodaphone uk. 3G was working fine using switch pro to turn it on and off, then I turn it on to download a MMS which it failed and now it won't turn on again!
I've put it on airplane mode and changed between network modes that used to enable me to turn it on again in 1.6 but it won't do anything now. I tried turning on and off the arrows show for about 30 seconds then it stops.
I had similar problems with 1.6 and that was the vodaphone 1.6 official version.
Why is the X10 so crap with 3G? I've tried numerous switchers on 1.6 and they all ended up stopping working after a while but I could always get it working again now it just failed.
Is there anything I should be doing to get MMS to work properly and how do I get 3G back? Any settings I need to put into the APN settings even though it seems everything is filled in automatically by selecting vodaphone as my network.
This is seriously pissing me off, is it a Android flaw in general or just the X10?
I would be totally happy with this phone apart from this which I keep thinking has gone away then starts up again!
Thanks for any help
Thanks for any help
