Help 3G to 4G??
dennis8492
I just recently rooted my ZTE Warp from boost mobile but im wondering if its possible to mod the network so it can go from 3g to 4g... is this possible?? or should i invest in a 4g phone.. im willing to use my phone as a tester.
The warp does not have a 4g radio so it will never have 4g.... and yes you should just invest in a 4g phone but first make sure that you have 4g coverage in your area
Sent from my N860 using Tapatalk 2 Beta-5
yeah keep in mind 4g only comes on phones that support 4g (usually indicated by '4g' somehwere in the phone's name)
What about modifying the phone so it can have the look and feel of a different android such as the evo?? Or is that something that can be done with a custom Rom?
You cannot physically modify a phone but you can customize just about every inch of the android os which is what custom roms pretty much are
You can use custom ROMs and go launcher has honeycomb and ics themes theres also the ics launcher which makes it look like android 4.0
Go Launcher ifs amazing. I do not have my phone rooted, but my ICS theme, 3d, and amazing transition affects make my phone look nothing like a stock warp. Give it a try, you'll love it.
I found this app that can toggle 4g it takes me to a hole new option looks like a new #code with out using the dialer if some one can pm me I can gave em them app and we can help each other out never know first warp with 4g
I'm sorry but as it was already stated above...this is not possible. The issue with the warp isn't software but hardware...we don't have a radio capable of connecting to a 4g network in this phone.
Notification toggle app then it haves a 2 fast button toggle click it a new opinion will appear it might not work but give it a try
