By placing the phone in 3G mode, how much battery life would this save compared to leaving it with LTE?
A LOT. Without delving into my settings, I get through a complete day, including probably 90 minutes worth of phone calls, 100 texts, words with friends for 20 minutes, 30 minutes of GPS navigation and maybe 20 minutes on facebook and still have about 20% around midnight. With 4G on, I'm lucky to get through half that time with much less usage.
Why buy a 4G phone to run it in 3G, .
Why buy a 4G phone to run it in 3G, besides at elast here in ATL VZ 3G SUCKS
I may be wrong, but I am thinking that the only time I really need to be concerned with actually using 4G is when I am doing anything that requires data.
Why buy a 4G phone to run it in 3G, besides at elast here in ATL VZ 3G SUCKS, if VZ did nto have 4G I would go ATT as their fake 4G is far better than VZ 3G. The VZ 4G is awesome. With light use I went 10 hours with 28% left and that was with several calls, texts some media BT streaming and some minor web browsing.
Verizon's 4G is "fake" too. It does not meet the 4G standards set out by the ITU. Both AT&T's HSPA+ and Verizon's LTE are pre-4G technologies meant to bridge the gap between 3G and 4G.
There's no such thing as "fake 4G." 4G is an abbreviation for 4th Generation... meaning it's the particular network's 4th upgrade to their data carry capabilities. Therefore it really means nothing in terms of speed, just the fact that it's the 4th major upgrade the company in question has made to their network. Just my 2¢
Wikipedia said:The current generation of mobile telecommunication networks are collectively known as 3G (for "third generation"). Although LTE is often marketed as 4G, first-release LTE does not fully comply with the IMT Advanced 4G requirements. The pre-4G standard is a step toward LTE Advanced, a 4th generation (4G)[3] standard of radio technologies designed to increase the capacity and speed of mobile telephone networks.
You're wrong. 4G is an actual set of inter-network standards. A mobile network has to have a certain speed to qualify as 4G.
So no, Verizon's LTE cannot, in any way besides marketing, be called 4G. They only call it 4G because "3.5G" sounds boring.
All the terms are just for marketing purposes. Just look at your internet at home, when your provider says 20Mbps, do you get that speed? Probably not.
None of the cell carriers have a real 4G speeds, but Verizon is the closest to that threshold than any other carriers.
I stand corrected... I was simply regurgitating what I was told by a VZW marketing rep (obviously a bad decision). It just made sense to me considering what you confirmed above; that 3G is 3rd generation, therefore 4G must mean 4th generation. Didn't realize it was really only half way there.
