Help 3gp movies audio quality sucks !!
A70_Slave
HI,
Can anybdy pl. advice me that movies (.3gp) audio quality is poor both in real player as well as default android player and same level of sound when using ear phones.
Where as the audio songs (mp3) was awesome in earpiece and out speakers.
Pl. suggest me some resol.???:confused:
.3gp movies always suck due to compression...convert the files to .avi or mp4 which give better quality...android can play both
Thanks Samrox !!!!
But Mp4 format not being played in my A70. showing msg " Video format not supported".
And my actual problem is with audio of .3gp but not the video quality.
Pl. tell me if any Audio settings while conversion???
There are multiple types of mp4 depending upon the codex...a70 can play some, cannnot play some...I use h.264 or divx codecs for my mp4s at 640x480 resolution ands 1000kbs video bitrate for awesome
E quality videos ...use real player to play them on phone...and I use AvS video editor to compile
video
resolution 320 x 480
bit rate 500kbps
h264 codec
audio
aac-lc
128kbps
sample rate 41000
any video converter and ripbot 264 are recommended
converters
320 by 480 resolution video will not be rendered in fullscreen in real player.. it will have black borders.. this is quite odd
but 640 by 480 will :)
