I recently acquired a Google ADP1 and loved the interface, the multitasking, etc. The integration of just about every service I use: google contacts, google calendar, gmail, google talk, is awesome. Go figure, from a google phone
I started using the phone to support an application by our research group at school in the Android Market called: WifiMapper ... if you're bored, try it out sometime. It helps you remember where APs are you've connected to over Wifi, your signal strength to them, and if you run the bandwidth test it will let you know what your connection speed was.
