Help 3pg-sound/video
PilooX94
Hello..
When I recently copied my 3pg files from my HTC Desire to my computer and
watched them, the sound disappeared..
I've tryed to convert ti AVI, same issue.
Is there any way to fix this problem ?
Thanks, best regards
PilooX94
**Edit**
I fixed it.. I used the converter program wrong, I used it to encode and convert, instead of just converting it.. If there is someone with the same problem you can use THIShttp://thugsatbay.com/tab/?q=tab-video-converter-encoderhttp://thugsatbay.com/tab/?q=tab-video-converter-encoder program to convert.
