Apps 3rd party library issue
Bee Torika
Hi : )
If I use 3rd party library as
compile 'org.hogehoge.mo:radioro:1.1'
in build.gradle , internet connection is necessary , right ?
(because I didnt put jar library into a project directly)
And a project ( or app) download jar library from internet, and then, 'saved it' ????
So once, it is downloaded, no more downloads after this time right ?
I am afraid that, a app try to download jar file each time the app is launched..
because it will took a time and make a app performance worse.
I 'think' , a library is download just once at the first time, and a library file is saved in somewhere in a project, and app uses downloaded library repeatedly.
something wrong with my thinking, plz tell me.... :blushDroid:
Yes the library is downloaded only the first time your code is compiled. After that, no need to re-download it.
Once installed, the app doesn't need to download that library, because it will be included in the APK.
Thanks always ! :thumbsupdroid:
