Root 3uk rooting help please
hi I have a hero that is on 3uk and recently user the goldcard method and wwe Rom to first debrand and then upgrade to 2.1. I'm now quite intrested in rooting the phone so that I can overclock it a little bit. can anyone be kind enough to just give me a quick guide on the EXACT steps I need to take to do this from where I am at the mo. many thanks in advance.
Hang on, do you want to root or switch to a custom ROM? The method would vary depending on which you wanted.
Well I was going to suggest goldcarding, but after what Slug said in this thread, there are a few simpler options to try first :)
