3way calling on AOSP 9.9.2 12/10/2101 update ROM
It seems as if i can make a 3way call on this ROM, anyone having that issue. I get a busy signal every time i try to make 3way conference call. Other than that im loving this ROM
Please i welcome all advice.
My stats
AOSP 9.9.2
2.6.29.6-AOSPmOD KERNEL
Two Point Blue Theme
Yep I talked about it a few months back many seem to have the same issue and yet a few some are able to do conference calls, if you flash over to any sense Rom 2.1 you will have no issues as soon as you go to 2.2 Rom either AOSP or CM6 you will most likely have the same issue, I gave up trying to resolve the issue with AOSP in the IRC
My stats
AOSP 9.9.2
Would be easy to dual boot AOSP of SD and LQ Sense - then you could swap and make the call without a reboot...
