4.0.4. pushed out
Can anyone who got 4.04 OTA on GSM Nexus comment on it? Is there any good improvement on battery life, UI speed, camera, volume, etc?
I'm running a GSM version on AT&T, just checked and nothing yet.
Running Yakju 4.0.2 btw.
You can either got to Factory Images for Nexus Devices - Google Support for Nexus Phones and Flagship Devices - Google Code and download the complete factory image (need to extract it and then manually flash the bootloader > radio > and ...image.zip [in that sequence] or download the OTA update from here http://android.clients.google.com/pa...F.7f97fbc1.zip and flash it via a custom recovery (note: for the latter method you can only us a custom recovery as with the stock it will fail). :)
I just flashed mine to 4.0.4 manually using Wug's tool and the stock image from the Google download page. No stress. Checking it out now...all I see differently is a new "Dock" option on the settings page. Are there release notes available yet?
I can tell you that the screen lag I used to experience is completely gone. Haven't noticed much else, except my Xoom is faster than it ever has been.
okay, I want to do this but not sure if i can. Ive been reading online about applying the update manually. I've used wugs toolkit to root/unlock then relock/unroot but when i originally changed my phone from yakujxx to yakuj it flashed a different radio then stock and ive read i need everything stock to apply the update myself..
Heres a screenshot
A6YCSbd7
Any help would be appreciated.
I received the notice last night and upgraded. I haven't noticed anything yet. There are supposed to be hundreds of changes but my guess they will be rarely noticed. There is supposed to be an improvement to the camera... which would be good. Anyone discover other changes?
