Help 4.0 update problem! please help
got the update but it failed to download, it wont retry to doenload, any subjestions?
You're wifi only, right? Reboot, go to airplane mode, then turn wifi back on, then go to "about" the xoom and check for updates. See if it gives you a new Notification. And make sure your wifi signal is solid.
