4.2.2 Does anyone have it?
D
Deleted User
Guest
My roommates Nexus 7 just got the 4.2.2. update. I tried to manually say "search update", but nothing was found.
How can i get this? Or just wait?
Thx in advance for any response.
-CF-
Unless you're rooted I'm not sure. You may just have to wait for the OTA to rollout to yours. You might be able to use adb if you're not rooted I'm just not sure. Check the 4.2.2 thread in the all things root forum. You may be able to use the nexus 10 toolkit to temp load a recovery and install 4.2.2, but you may have to unlock the boot loader to even do that.
i found a few links online for manual installation instructions. i might try that..... but its already rolled out so if i wait, im sure ill get it.
I'm just not sure how the rollouts work! haha.
havent thought about rooting yet, havent found any reasons yet!
thx for the response
Not sure how long it will take, but manual installation doesn't require root or even being unlocked. Just one adb command to side load and your good to go.
If you are unlocked, and still have stock recovery, you can boot cwm or twrp and flash the zip file in that.
I've always found patience is a virtue with these kinds of things. From what I've read the update offers minor bug fixes and a slight boost in performance, nothing too crazy considering how well the Nexus 10 works already if you ask me.
atmazzz, think this will work? Update Nexus 10 to Official Android 4.2.2 Jelly Bean with JDQ39 OTA Firmware [How to Install] - IBTimes UK
im impatient haha!
I just waited until I got a notifications that a System Update has been downloaded and installed it. I would be patient; maybe reboot.
I considered manually updating it myself but as it's a minor update I'm going to wait. If it was Key Lime Pie I'd be all over it though haha.
I read somewhere key lime pie will be the next update after 4.2.2. Probably during the Google I/O conference.
Yeah pretty sure I read that also, happy with that, really looking forward to seeing the feature list for it.
I did encounter a lockup last night after my update to 4.2.2. I decided to give it a FDR, however, I chose not to auto restore apps when logging into the tablet.
Hopefully this helps as I'm at wit's end.
Tried the Settings -> Apps -> All -> Google Services Framework
clear cache & data trick and got the update OTA first time. Haven't noticed any big differences yet, but at least I can stop checking for the update.
Got mine last night after clearing out the Google Services Framework.
I got a random reboot this morning. Hope its unrelated. I was playing the Simpsons Tapped Out.
Aren't you rooted? Download 4.2.2 from the link in the all things root forum or root guide and you can just flash it in recovery.
It'll work properly going directly to 4.2.2 from 4.2.0 right?
Be nice to finally fix this thing. Sick of the update icon in the tray
