Finding update package...
I:Update location: /cache/5939ff985946.signed-mysid-JDQ39-from-JRO03O.5939ff98.zip
Opening update package...
I:2 key(s) loaded from /res/keys
Verifying update package...
I:comment is 1604 bytes; signature 1586 bytes from end
I:whole-file signature verified against key 0
I:verify_file returned 0
Installing update...
installing samsung updater extensions
installing samsung updater extensions for toro
Verifying current system...
contents of partition "/dev/block/platform/omap/omap_hsmmc.0/by-name/boot" didn't match EMMC:/dev/block/platform/omap/omap_hsmmc.0/by-name/boot:4470784:fbd13c778b34fdb7917c1ccee6389aa9b13a92bd:4505600:a62e93d5d96d19351ce2ce330bbcdccb248395fb
file "EMMC:/dev/block/platform/omap/omap_hsmmc.0/by-name/boot:4470784:fbd13c778b34fdb7917c1ccee6389aa9b13a92bd:4505600:a62e93d5d96d19351ce2ce330bbcdccb248395fb" doesn't have any of expected sha1 sums; checking cache
failed to stat "/cache/saved.file": No such file or directory
failed to load cache file
script aborted: assert failed: apply_patch_check("EMMC:/dev/block/platform/omap/omap_hsmmc.0/by-name/boot:4470784:fbd13c778b34fdb7917c1ccee6389aa9b13a92bd:4505600:a62e93d5d96d19351ce2ce330bbcdccb248395fb")
E:Error in /cache/5939ff985946.signed-mysid-JDQ39-from-JRO03O.5939ff98.zip
(Status 7)
Installation aborted.
It was, actually. How did you know? Trying a thousand different things ended up messing up the architecture of my SD partition, and so updating became a huge problem. I even installed a ROM, but so much was jacked from different kernels and recoveries that it was a convoluted mess.
I ended up wiping the whole thing (SD and all) and freshly installing 4.2.2 from Google's image that they just released. It was some work, but I'm glad to have a nice, crisp, fresh install.
Have you frozen any bloatware (vzw apps) or flashed a custom recovery or kernel?
