4.2.2 Quick Controls
timetoroot
Ever since I upgraded to 4.2.2, when I enable quick controls in the stock browser , the URL bar text disappears but the space it was in stays. Sometimes it'll go away but most of the time it doesn't. Anyone else have this problem?
did you wipe data after you upgraded?
you could try and wipe the cache/data in the stock web browser app in your settings > app menu. That might help you out.
Thought I would bump this to see if anyone else is having this problem and found a solution. It appears that Lite flow is not the culprit as I uninstalled but still have the problem.
