Root 4.2.2 [Unofficial] CarbonRom [ALPHA]
jssa28
CarbonRom is an aftermarket firmware based on the Android Open Source Project. We are dedicated to fast, stable, and feature-filled roms, honesty and communication with our users, and openness with our code. We like frequent builds, with the very latest and greatest hardware support and fixes. We strive to not only provide you with the best rom we can build, but also to give back to the Android community and our fellow developers. For us, this is about creating something we can be proud of and hope you will enjoy.
For more info : Carbon Rom
Built from Source -
Not working:
Video Cam
Front Camera (Rear Cam Works)
If ADB debugging is enabled there is no mass storage
Streaming Apps (Youtube, Netflix)
Tell me, bugs will exist it is an alpha release.
Major features not listed should be working.
1. Full Wipe (system data cache dalvik)
2. Flash this zip
3. Flash these Gapps
4. After first boot goes to homescreen, give it a few seconds stuff must load and it will lag a bit during this time
Let me know any issues :D About GSM international phones, might need a tester.
If you like my work and would like to donate.
I've tried with TWRP , CWM & it said bad install , not sure why... please help..... would like to try this ROM ..
.............,..............................Solved......
Thank you SOOOOOO much for this, I've been looking forward to kit kat for a while now, and i feel very lucky to try it! Downloading now, thanks!
My own compilation cm10.1, front camera is available, but will be libandroid_servers.so Over here so can't use, but can be used aosp4.2.2,why so?
carbon camera source must be different than cm, hopefully someone can fix the cam for this phone for good:D
use the rom for two days ago, I found.
GSM, can make and receive calls but not SMS, I see that does not recognize the phone number
the front camera does not work,
youtube does not work as mentioned,
in some applications not obtain Connection,
Frequent restarts today,
For the rest, very good work
Thank you.
1. Whenever i configure wifi proxy manually settings force close.
2. Games like subway surfers lag. It used to run smoothly on your clue kingdom's rom.
3. LED issues.
4. It would be great if we can get a bit more stable camera.
Anyways Thanks for dis wonderfull rom.
[/QUOTE]
I cant get the Gapps link to work. It gives me a 404 not found error. Anyone else getting this?
I'm still getting this error and I'm surprised that Noone has replied to my comment yet. I've tried from my laptop and also my phone with no luck. Last try was one minute ago from my phone.
Interesting... can you try another browser? Works everywhere for me
Thanks for putting together this nice rom!
After wiping system, data and dalvik cache I installed this rom and have the following findings for you:
1. The home button doesn't seem to work for me.
2. After pairing with another android phone, when I tried to send a file to this phone, I got a message to confirm the transfer but it didn't show the screen where I could actually confirm it.
Here is a couple of things I hope you would consider incorporating in this rom:
1. Would love to be able to use CDMA APN for making a data connection. This will help people using RUIM and also ones that have problem with MMS hopefully.
I did some digging to get more info about it. For Froyo/GB, it seems, to use APN for CDMA mode, a couple of java scripts needed to be modified in framework.jar(it was for HTC Rhodium though). Here is the link for the changes in the code:
https://gitorious.org/xdandroid/frameworks_base/commit/e0fa513741f513476a0d17d1fd6236b23d7dec02
Without the mod, the system uses null for apn, user and password. With the mod, the system retrieves the APN defined for the CDMA carrier and passes on that information while making a datacall. With this mod, the system will use APN info if set up or else it will continue to behave like it does now.
I'm hoping that similar code exists for our device and would be easier for a master like you to implement this mod. The devs for the other phone also changed phone.apk to show APN options in phone.apk but we can perhaps use AnyCut and get to the APN settings by creating a shortcut to it hopefully and not needing to modify phone.apk.
2. It would be nice if we could connect to Adhoc WiFi networks too.
Thanks again for doing such wonderful work!!
you need install gapps
system/build.prop,"310120" Modify the code for your operators,
system/etc/apn-conf.xml,Add your apn of operators,and Remove about 310120 rows
After modification, in China use it very well
Alot better and more stable than the other 4.2.2 rom, glad the camera works, would love if front facing cam could be fixed, also camera force closes whenever it recognizes a face, and gallery force closes when entering photo editor.. but overall awesome rom. Looking forward to KitKats release... Thanks for the much needed updates :)
