JJPR97
Thank Connorh333 for this, I decided to make it a thread for those having trouble/so people can see it.
This has only been tested for CyanogenMod 10 B3.
It has worked.
Either way make a backup in CWM.
If anything should go wrong, only you are responsible.
What you need:
- An LG Lucid.
- Root Access in the LG Lucid.
- ClockWorkMod Recovery (Not sure if they have TWRP for the Lucid, but it is also untested, but out of common sense it should work.)
1. Flash/Reflash B3
- It will keep your stuff, no need to wipe the cache, dalvik cache, or factory reset.
2. Flash the 4.2 GAPPS [Thank Connorh333 for the GAPPS and link.]
3. Get a system app uninstaller, uninstall Google Search and uninstall GALLERY!
- Delete the gallery .apk and Google Search. (/system/app)
- Delete them and uninstall them if you must.
- Google Search won't be named 'Googlesearch.apk' or anything similar, just look for the logo.
- Recommend System App Uninstaller click here.
4. Goto Google Play, re-install Google Search.
5. Install the Gallery2.apk
Enjoy 4.2 GAPPS.
Once again thank Connorh333!!!
A quote from Connorh333: "I did not create these gapps, all credit goes to Garner at xda-developers"
Make sure to thank Garner at xda-developers!
It has worked.
What you need:
- An LG Lucid.
1. Flash/Reflash B3
Enjoy 4.2 GAPPS.
