4.3 Stock Battery Life Screenshots
xploPR
Android Expert
I was using bluetooth today, Wifi & streaming from slacker radio on the car.
Just got home since 8:00 am on the road on one single charged. 12+ hours and 2% Not bad i think.
How is battery working for you on 4.3?
Looks pretty reasonable - the screen appears to have been on quite a bit judging by the second image. It doesn't look wildly different to what I get with 4.2.2.
I had my first full day on 4.3 yesterday & got fantastic battery life. I played a couple of battery heavy games (not for long though) and the phone lasted me a full 24 hours with about 20% battery left. Normally I'd only get around 16 hours of use and have that 20% left.
My phone wouldn't charge last night though. I restarted it this morning and it worked. Not sure if this is 4.3 related or USB. My 1st instinct is USB but I digress
If my screen is on for just light use, I still have trouble getting 8-10hrs of battery with 3hrs screen time. His screenshot looks like 6hrs maybe, but that's hard to believe!
I know that LG sells a replacement batter, but is there a longer lasting battery that can go in the Nexus 4?
I've noticed that my stock 4.3 update seems to be giving worse battery life.
I'm usually @ my work place with airplane settings on because of poor signal penetration & can stay in the 80+% battery status for most of the day even when I step out to get a signal.
Now, after 4.3 update - noticed occasional 'coffee breaks' & turning off airplane to check emails usually puts me down to 60% by end of day.
