Skuduriukas
Hi. first of all topic about the storage truth didnt help, beciuse there is no answer how to make device write apps to sdcard. any help? tried rooting but phone didnt let me do that
First off, it never claimed that it was for that. It said that it was to help you to see how your storage was used. Not why your apps don't work, not how to email, root your phone or anything else.Hi. first of all topic about the storage truth didnt help, beciuse there is no answer how to make device write apps to sdcard. any help? tried rooting but phone didnt let me do that
Not necessarily ok.so u wanna say i cant download 4gb game becouse my storage too low and sd card is usseles?![]()
I am not surprised.okay for example i have 2 eternal disks. one is 1 gb 2nd is 4 gb and then 16gb sd card. but if it says 'game is on sd' so for real its on 2nd eternal 4gb disk but not in sd
There is a root modification called Link2SD...
i have 100mb app storage and 1gb data storage and i cant update any app becouse "there is not enough space" but what the hell if update need only 2-3 mb?
im so sad and angryin post #15 i sayedYou never told us what device you have.
Generally once available space gets below a certain amount you will get the "insufficient space" warning when you attempt to install any additional apps. If you aren't able/willing to root your device (or if there is no available root for it) then there isn't much you can do.
i want to root but cant find normal rooting tutorial step by step which works
