4000mah battery
sb43
Android Expert
I just bought a new 4000 mah replacement battery & back cover for my Warp. Now I can have a little longer life on this MONSTER!:)
alright so im wondering if i should buy it. and i heard you cannot use your same case if you get the battery because the battery is bigger and you need to get a case that fits with the batter, so you phone will be bigger.
is there any other batterys that fit perfectly in the zte without having a big ass battery. maybe theres like 3000mah thats the default battery size. because i dont want to buy a new case and i want my phone to be same size, i dont want it any bigger.
also how long does the battery last?
i dont want it any bigger. THAT'S WHAT SHE SAID....
also how long does the battery last? THAT'S WHAT SHE ASKED...
Try Amazon or Ebay. You will find larger than stock battery that fits your phone. Unfortunately, it won't be 3000mah or higher. More like in the low 2000 range...
I have the 3800mah battery and it is just 2 regular batteries stuck together(yes I tampered with the battery case, don't do this at home)
compared to stock battery it improves talk time by 2x and standby time(with data off) is about 5x improved
They come as 3800 or 2800. You have a plug in that you slip the battery in to. You get two batteries so when one dies you have another one already charged.
Well, i got my 4000 mah friday. Love it. Other than it being bulkier, great. Got to sacrifice beauty for performance
I just wish i could find a gel cover for the extended back. Tried stretching mine.(doesn't work).
Just got my 4 Amp last week... absolutely awesome :-) Nothing beats being able to go 2 - 2.5 days between charges on Lagfree.
