Help 49% Cell Standby
skater95
I know about the 50% without service bug and my phone has it, but I did the airplane trick and I don't have any time without service anymore, but I still have a high amount of time from cell standby. Is there a way to get rid of it? Or is my phone still having a problem? My phone battery will only last about 12 hours, so my battery life has gone up
How much use does your phone get? With moderate use it should get 24 hours. Mine with very little use will go 48 hours.
DO you use widgets, live wallpaper, power panel etc? Do you use any apps like Weatherbug that require updating? All these things will run down your battery.
I hav the 50% bug and i can get 24 hours with light use on somedays and 12-15 with light use on others i run atk and juice defender I think they help and its all a preference. Is there a way to find someone without the 50% bug and create a rom for a short fix before froyo?
Already asked about this, ROM wont fix it, need a whole new OS
Moderate use maybe a little more, and no I don't use live wallpapers widgets or sync anything and I shut the syncing off
Try uninstalling ATK. You don't need it. The less you use your phone the better Juice Defender works. Do this at least once a day. Turn airplane mode on, turn your phone off, wait 2 minutes, turn phone back on, turn airplane mode off. Your ram should be greater and your phone should be faster. Also, make sure to uninstall Power Panel. It is a ram and juice hog. See if all that helps.
How do you uninstall power panel?
