I believe it might, older HTC phones had the 3G/2G toggle
The aria doesn't have that option either. Att is bad about screwing up the android system. Can anyone confirm this with a screenshot? It would b great to know.
The aria doesnt in the power toggles??
Nope. AT&T disabled that option on the aria. I don't know why though. On my iPhones and blackberries I always switched it to 2g when I was at work due to such a poor 3G signal and it really helps with battery life
well if this option isnt available on the inspire which i cant see. You can always download beautiful widgets they have those toggles
Beautiful widgets toggle didn't work on my captivate. Has anyone been able to confirm this yet?
they work on my captivate
So with the beautiful widgets you can force your phone into edge? Do you have an AT&T captivate or Canadian one?
I haven't rooted my phone or anything. IS that why I can't get that option?
My question has been answered by @HTCSource I asked
@HTCSource How long did you end up getting out of the inspire and what kind of use did you put it through? Can it be forced to 3G or 2g?
@phillip_price on average, the inspire has been lasting me 10 to 12 hours with moderate to heavy usage. No option to switch between 2G/3G
Very disappointing for me to hear that, and pair it with the new 4G plans, I may stick with my captivate longer than I thought.
Man that stinks. For me its not a deal breaker but you it seemed important
I only can get an edge signal at work, so it was very important for me. Oh well. I'll hold off on the 4G phones till that is fixed. Maybe I'll just change jobs instead and still get it![]()
Well if that's all.you can get that shouldn't mess with your battery then
Using Any Cut I was able to access a few hidden screens. On both screens I changed from CDMA preferred to GSM Only. The changes stick on the screens, but they have no effect or operation of the phone. That is, regardless of the setting, the phone stays in 4g mode.There is an option hidden away to toggle WCDMA or GSM-only.
Tap "Phone"
Type: *#*#4636#*#*
The "Testing" menu should open.
Tap "Phone Information"
scroll down to "Set preferred network type" and select GSM only for 2G operation. Selecting "WCDMA Only" will not allow a 2G connection.
