4G Channel Bandwidth
To check: If you already know your service code skip to step 3
1. Go to android - whiterabbit.org
2. Enter your IMEI where it says MEID/ESN then hit calculate write down the six digit MSL code
3. In the dialer enter ##626* then when the service code box pops up put the 6 digit MSL code in
4. Go to field tests and the channel bandwidth is at the bottom.
Sidenote: if you go down to network select then network mode you get this http://db.tt/JKl7ZLEQ
