Root 4G gone.
biggiephil
Hey guys I've recently used LGs update tool to get back to stock firmware F and now I only have 1x :/ I'm stumped. Someone have any fix without re flashing or something?/:
were u running a custom rom before this? be specific on what you did to ur phone before you lost your 4g also jus in case make sure ur iccid card isnt loose
I was running CM 10 the latest one from Playfulgod. I had 4G Previous to that. I don't anymore
EDIT: I did mess around with the service settings while I was running that ROM, maybe I turned something off
EDIT: How do i access the hidden menu to turn 4G back on?
