4G Icon
aciulladev
Member
I was looking through the user manual and when it would show the phone on 4g, it would have a 4glte sign which looked cooler. How do i make it get that icon?
You should find the 4G icon in
System/app/systemui.apk extract the file look for drawble mdpi or hdpi and look for the 4G icon it should be their
well how do I change it to the ATT version of the 4g icon. Is there like a tutorial or something, because I do not like the default one.
Try to look for mdpi icon but i already try looking for one and no luck... you have to make it your own
Just use ROM toolbox pro, it has a search function in the build.prop menu.
Nice find, minor issue is that after modifying the line it show metro pcs on the left side of my status bar.
(Edit) make sure to change the line back to stock if a new update appears. I just tried using software update as a test and it states that my device is not registered.
