Same here but mines turned off at 2.
Works great in Dallas as well.
If you guys are still having problems with loosing your 4g try this out it should keep your 4g on, dial **583385## once you enter that number a window gonna pop up you should see three boxes your only gonna choose one that's called ( enable global mode) click on it then its gonna asked you to reboot your device reboot and that's it you should have your 4g back,![]()
Cut off again and that number doesn't work
Here in Dallas as well, although there are some nights were 4G goes to 3G and I have to reboot the phone for the 4G to come back on.
Is metro dropping towers/less coverage or something
