I have noticed that there is now a 4g version of this phone available on some ads. Previously AT&t seemed to only offer the skyrocket as their Galaxy S2 option. Is this correct? Is there now a Galaxy S2 that is identical to the 3G version available in 4g?
Very VERY envious...
aylonewolf69, Thanks for your wonderful reply. I am also partial to I777 for its more intriguing processor and it's size. I don't think I will like a fat phone. If I am not mistaken the specs looks very similar to the Nexus Prime on Verizon. Once it has Ice Cream Sandwich, it could be the same phone if there was a way to turn on the Near Field Communication that seems already build into the I777. Please correct my assumptions if I am off base here. I am very into getting this phone. The reason I am hesitant of going for the Nexus Prime is because I would like the option of popping out the sim card and going over seas or using it later in life without a data plan. Does any of this logic make sense or am I just being goofy?
Thanks again for your reply.
Couple of things:Glad you liked my REPLY!Couple of things:
Nexus Prime - IMHO is a step backwards in hardware, again ***IMHO*** 5mp main camera?!!??!? Really, Samsung what were you thinking?!?? I was hoping for Galaxy SII Nexus Prime with Android 4.0 (Ice Cream Sandwich) but 5mp camera, Snapdragon CPU instead of Exynos really not the *BEST* of the best...
Going overseas with the unit... Three or Four weeks ago when I first got the phone, there was a chap here, or on XDA forum that kept going back and forth about taking the AT&T overseas but not being able to change carriers... Sure, you can switch the SIM cards and make calls with it, BUT, you're ***LOCKED*** to the carrier that AT&T prefers. For instance if you go to another country let's say HK, then you can use the SIM cards there however, if you LEAVE HK and go into Mainland China you may be presented with a choice of *different* carriers other than the MAIN one from HK some will charge ROAMING fees while others are part of the plan... IT is here that AT&T has locked down the RADIO, on unlocked phones you should be able to *PICK* which radio/carrier you use outside the main city but with the LOCKED phone you will not be able to choose and it *MAY* connect you to the carrier with the ROAMING charges because of AT&T *alliance* even though there is CHEAPER/BETTER service without ROAMING charges... From what I READ, the I777 was locked and choice of carrier/radio was not unlockable...
Overseas and AT&T I777 not such a good combination... So, if this is your primary goal, I would strongly suggest you go with the Internation version of the phone the i9100 instead of AT&T I777...
Good Luck!!!
