4G settings on dInc?
was messing with ADW for the first time and went to make a custom shortcut and found this, anyone know what its for?
kinda hard to see the reverse picture; the checkbox says "4G" and below it, "turn on 4G."
then below that:
network provider
signal strength
IP address
it wasn't in the original settings menu (that i could find) but when i went to ADW Activities, i saw it listed there as 4G settings(.wimax.WimaxSettings)
Its probly just part of the OS that is not used,dink antenna is not 4g compatable.But where in the menu did you see this,I cant seem to find it
this was discussed in a thread before and like mention the OS has some "generic" features built into the rom that is active to some phones. This would be turned on in the evo builds. So if you load an EVO ROM this would be active on it
if your running ADW (or launcher pro i would guess) create a custom shortcut, then goto
adw activities > settings > 4G settings(.wimax.WimaxSettings)
Makes sense about the generic features though, thanks guys.
