Root 4g speed tweaks?
I'm curious about this as well. I remember when I was still on the LG Optimus M, in QPST if you set the ip mode different it gave the data a little 100 kbps boost. For me at least. But since this is about LTE, not CDMA specifically, I highly doubt that would work.
There are build.prop tweaks I use on my Esteem that actually seem to help.
ro.ril.hsxpa=3
ro.ril.gprsclass=12
Another thing that helped was removing metro's proxy settings. Kanaida's app has a shortcut to it, or you can use any cut and keep trying LG hidden menu shortcuts.
ro.ril.hsxpa=3
ro.ril.gprsclass=12
Is there a way to remove the proxy settings using something like QPST?
BrokenOut doesn't seem to have the LG hidden menus...or at least they're not showing up on anycut.
