Root 4G Speed Tweaks?
ManlyParasite
I have some pretty poor 4G speeds in my area, and I just started looking for some ways to speed it up. I saw the build.prop tweaks in ldrifta's #2 rom, and applied those to my phone using Rom Toolbox. My speed went up. There was a thread a couple weeks, maybe a month ago with posts of speed screenshots, mine was like 400-450 kbps. The tweaks he had boosted my speed up to 670-760 kbps. Still slow by most/all standards, but still better than before.
I then Googled "build prop tweaks 4g speed" and the first thing I saw was a post on these forums, for the Samsung Galaxy Attain. I figured, that since they're both using Metro's LTE network, the build prop tweaks in that post would work as well, since it seemed to have worked for them.
Well...it didnt. My speed actually suffered, and dropped to the 300-350 range, worse than I was before.
The below screenshot were tests, the bottom 3 were with ldrifta's tweak, the top 3 were with the tweaks for the Attain. A reboot was done after applying each set of tweaks.
I don't know why the first test was so low, maybe it was still booting up when I did the test.
I'm still searching for other tweaks to try, so far these are the only 2 I've found and used, if anybody knows of others, please post them.
EDIT: I used the 2nd set of tweaks together with ldrifta's, when I did the test they were both active.
i speculate that to further bypass our capped speeds we would have to edit the prl file which i will add i tried doing but wasnt sucessful in finding an editor for it.
i put in those speed lines myself, i was gobbling up 13-17mb last night around 10pm.... stupid fast
Theres an app for that.....provision.netspeed.optimizer aka 3g/4g speed tweaks. I wasnt terribly impressed but hey, different area maybe youll get better results...try LTE speedtest app for an alternate testing app
