4XL...Txt is random
I have 4XL....I can txt to almost everyone I want to....and recieve txts from them....
But I have one person who does not get my txts.....nor can I recieve his txts....
This started about a week ago....
Previously we have always been able to txt each other....
We have both rebooted our phones....he is on an iPhone...
Any thoughts on how to fix this...???
this has been an on going issue with android and apple users. is he using imessage or your standard sms/mms? imessage is for apple users only which is why you are not getting or receiving his text messages.
iMessage should revert to SMS/MMS when sending to someone who isn't an iMessage user. The problem is usually when someone switches to Android without signing out of iMessage first, because then iPhones will still think they should send iMessages to them.
Them not receiving is even odder. Do you use the same network? I wouldn't ask that in Europe where our systems are more uniform, but I've heard of the mix of different cellular technologies in the States sometimes causing problems with messaging, so it's a factor to consider (plus if you use the same carrier it's easier to ask them to investigate).
I am inclined to think it's at the iPhone end just because it's easier for iOS users to be using something other than standard SMS/MMS without realising, but just to be sure maybe try sending a message from a third party SMS app that doesn't support RCS ("chat" as Google call it), or turn that feature off in your Messages app and then try. I don't think your phone should send RCS messages by mistake to someone who isn't signed-up to that service, but as that would be similar to the iMessage problem it seems only fair to consider the possibility.
