Dror Zohar
Following the update I got a couple of error message about programs crashing.
And since then the phone just wont charge at all. The battery, which was ok before, is empty and it wont charge at all. Even when the phone is off.
Has anyone heard of something like that happening?
What can I do?
What can I do?
Now, it might be possible that the load (and/or heat) of the update stressed a marginal battery just enough to push it over the edge, but if the phone won't even charge when off, then it sounds like a hardware failure.
