ricbaez
It should be saved under screenshotsCan't seem to find where screen recording is saved, recording with power menu from rom settings
There should be an option in the settings for switching the connection type when connecting to USB. I'm not 100% sure since I'm using cm12.1, but if there is, just switch it from mtp (camera) to ptp.USB DEBUGGING
I can transfer pictures from phone to PC. Comes up as G4
***I can't transfer other files***
Anyone else have issues with this?
You used the ms345 recovery and the ms345 version of this ROM?Which version of stock are you all on? I am on h34510f. I have tried both recoveries and both this rom and cm 12 and neither will flash.
Yes to both. I get nothing but errors.You used the ms345 recovery and the ms345 version of this ROM?
Not the c50 or h345 version.
Did you flash anything else? Mods, busybox, supersu?Yes to both. I get nothing but errors.
Update-got it to flash by re downloading both the recovery and rom zip, but all i get when the phone finished booting is a blank screen.
Only other thing I flashed was gapps. Yep did a full wipe. Will try to do a full wipe including internal storage when i get home tonight.Did you flash anything else? Mods, busybox, supersu?
Did you do a full wipe before flashing? (Dalvik, cache, data and system?) If so have you tried moving needed data off of internal SD and wiping that too?
Worked the second time. Thanks for the help.I had trouble too but I flashed ms345 with blue TWRP v2.8.7.0 Let it sit for 5 minutes, then rebooted (by battery pull) and flashed gapps. For some reason my first 2 boots got stuck on a blank screen but I just battery-pulled and it booted up fine the 3rd reboot.
Ive used ms345 v10f, 10g, 10h (metro) usually metro and tmobile roms are interchangeableWhich version of stock are you all on? I am on h34510f. I have tried both recoveries and both this rom and cm 12 and neither will flash.
There's no way this should have gone through since this is based from a zte device. It probably quit the install and you're just witnessing placibo effects.So I was just looking around for kernels for 5.1.1 and I found this kernel (link below) and after backing everything up in twrp I gave it a shot and I got an error message but it went through when I flashed the zip...i was able to bootup just don't know if it did anything...if any of the advanced homies can see if it works...again do a back up as I did to cover yourself
I was able to see a slight difference in the phone and contacts lag I was having...receiving calls etc but that's just me lol
Again backup before testing just wanted to share
http://androidforums.com/threads/bankermod-5-1-1-kernel.929674//URL]
Try it again... I just downloaded.The link to the MS345 ROM doesn't seem to be working. Can anyone load up an additional mirror that isn't on c0urier.net?
