What can I say? I updated the my 50 Nexus 7 tips videos for the New Nexus 7 and condensed it into 20 minutes
How to place an app on screen
How to remove an app
How to uninstall an app
How to create a folder
How to name a folder
How to manage the folder
How to delete a folder
How to use the task manager
How to show notifications or options
How to quickly turn bluetooth and wifi on/off
How to take a Screenshot
How to enlarge/reduce a snapshot notication
How to remove a single notification
How to remove all notifications
How to change individual sounds
How to turn off keyboard sounds
How to get a Jellybean
How to fling jellbeans
How to get developer options
How to disable system applications
How to disable app notifications
How to reset application defaults
How to triple tap zoom
How to copy and paste
How to allow install of 3rd party apps
How to Install Flash
How to push an app install to the N7 from google play
How to Connect a Bluetooth Mouse
How to connect USB devices to your N7
How to set the N7 to harddrive or camera
How to transfer files
How to view files on your Nexus 7
How to change your launcher
How to do stuff with the gallery
How to deleting images from the gallery
How to check for software updates
How to to get Googleplay Refunds
How to manage a widget
How to save power by turning off wifi
How to see my downloads
How to create a lockscreen message
How to prevent creation of app icons on install
How to turn off auto syncing for accounts
How to turn off all auto syncing
How to turn off pulse notification light
How to add a lockscreen widget
How to remove a lockscreen widget
How to uninstall system app updates
How to turn off application auto update
How to cold boot tablet
Hope you find it useful and please share!
