50%, Silent call bugs?
gish
If you have the 50% bug sometimes, does that make your phone more likely to have the silent call bug? I got my phone less than a month ago, and have only occasionally had the 50% bug, and want to make sure it's not indicative of having a defective unit.
Well, the silent call bug is indicative of a defective unit, in my opinion.
We've seen reports of those two particular issues in the same device, many times, however I'm not sure if they necessarily go hand in hand, as you ask.
If I had that silent call bug I'd be back in that store post haste for a replacement, if a factory data reset did not remedy it first.
They certainly do not go hand in hand. At least in my case. My phone works perfectly fine, other than the 50% bug. Some Moto Droids also have the 50% bug and it uses normal vanilla Android so I think its more of a 2.1 issue than an Eris specific one.
Thankfully, I don't seem to have the silent call issue. I was just concerned that if I had one bug, there might be more I don't know about yet.
That 50% thing seems to be a display issue in 2.1, although we've seen some report that their battery life suffered following its appearance with 2.1.
I was among those who originally believed it was affecting battery life, but since then I've decided it's just affecting the battery meter, and that affect goes away with time as long as you're not constantly doing the airplane mode trick. (When you do the airplane trick, you're training your battery meter to only work correctly with the airplane trick.)
I've been wanting to hire a sky writer to get the word out on that.
Expensive these days.
Well, I don't know, nestor.
It's just that the cute fuzzy little animal thing is kind of our of my area of focus these days.. it's been decades, as a matter of fact.
Got anything a bit more, Ren and Stimpy-ish?
I have noticed that the silent call only shows its ugly head on my Eris when the battery is low in charge...
Does that match anyone else?
Oz
