r1dePrkCty
Member
I know this was discussed as being rumored, but does anyone know if Froyo will actually be able to see all 512mb of RAM?
and how long before we get it? hell...I didn't get the last update![]()
Yes, it's one of the features listed on the feature page by Google.
when did you get your phone?
what update are ppl talking about i just got my phone last month and it says 2.1 update 1 on it. was there another one?
Aside from being 2 months old, my Incredible, under "SD card & phone storage", under "Phone memory" lists 748MB for "total space" and 558MB remaining.
Seems like it not just has 512MB, but it has nearly 50% OVER that.
No, it wasn't sarcasm actually. I'm probably misunderstanding something, but I assure you I know the difference between primary (RAM) and secondary (Hard Drive, etc.) storage mediums. I've built several computers over the years, and I'm not about to confuse the two.
That said, the "748MB total space" under "Phone memory" is NOT my phone's secondary flash storage; that would be listed under the "Internal Phone Storage" header, and clocks in at "6.60GB" -- a bit more than the 748MB I mentioned.
Which does beg the question: why does it say 748MB at all? (I have a 16GB microSD in there too, but it's under the "SD card" header) 748 seems a bit high for the internal RAM (isn't it?).
Your phone has 8GB of internal memory. 748MB of it is allocated to apps (known as "Phone Memory"). 6.6GB is for media storage (what we know as the "Internal Storage"). The rest of the 8GB is lost to formatting.
That makes a bit more sense (logically), but is foolish of them to partition the internal storage at all.
That said: my phone says it's using 10% of it's memory (50MB) per System Panel, meaning it's seeing roughly 500MB. I'm not sure what people are saying that their phone doesn't see all 512MB (unless, of course, System Panel is also misleading).
You mean you have 50MB free. 2.1 can't see any more than 256MB and thus only half of our RAM can be used right now.
I was mistaken with my first post: I do have only ~50MB free, however it also says I'm using 90%. So my math was still correct: if 50MB = the 10% I still have free, the total is 50MB/0.1 = 500MB.
Unless System Panel sees the 256 "unused" and considers it "busy", or some other work-around, it seems like mine is seeing more than 256, though I'd be a bit surprised if everyone else is reporting the opposite.
