5LINX VELOCITY V2 tablet - HELP
WarSxNes
Tablet's specifications:
BRAND: 5LINX
MODEL: VELOCITY V2
OS: ???? (But I guess is Android 4.1.1 Jelly Bean)
BUTTONS: POWER, and a little hidden button. (no volume buttons, or home included)
https://5linxvelocity.5linx.com/default.aspx?rin=L392298&affiliate=5
Ok... that was a nicely post, BUT... When I read this part: I QQ
You'll also need to have USB debugging enabled on your device
That was very sad. BUT... why that say:
which can be found under Settings >> Applications >> Development.
That is like you know in a specific day you will forget the password. That has no sense. o.o?
In my case my daughter was playing with her tablet and I don't know how the hell LOL (sorry to say it) she put a password, but she did.
Well... I TRIED and followed the instructions on the video, but I got this error.
Also, installed the drivers Android Debug Bridge (ADB) I guess a little popup window should appear when I plug in the tablet right?
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
error: device not foundy:
So I guess I never enabled USB debugging. How I was to be expected that I had to activate it. lol sad very sad.
Another idea?
I only have two buttons, power and a little hidden button. And I only get access to the screen where appears an android robot with a red triangle. (pressing power and the tiny button at the same time, then I release the power button and keep pressed the hidden button until the screen with the android robot with the red triangle apprears) But nothing more.
I know the next step is press the volume button, but that evil etablet hasn't it.
And, if I let loading the OS, then desktop (idk how you call it) appears and ask me the password.
Help... Help,,, =) what can I do?
OMG I suxx,,, sad too sad..
Ok, That should have been a great way to bypass the password. BUT OOOooOo krishchis!!!!@#$ Now, I remember a couple days ago I turned OFF the WiFi on the tablet. ((yes the evil icon is grey))
So, If I'm not bad, to unlock it you need get access I mean the tablet to wifi to get sync with google play right?
When I was reading the article, I watched another ad that sent me to:
How to flash VIA 8850 Tablet PC
I know this is another brand, but I remember 5LINX support told me something about of REFLASH the tablet, but they said can't help me cuz I don't have a warranty and the software had copyrights
Do you think guys I can do that? I mean reflash the tablet using a MicroSD?
If yes, exist a universal Android OS for all devices or I need a specific OS?, I was watching a video how to install linux ubuntu but I guess I need wait.
--==RESUME==--
BUTTONS: POWER, Little hidden button, (no volume buttons included)
WIFI: is OFF
USB Debugging: is OFF
THANK you for your patience and your time.
HELP... HELP what can I do?
