Root .602 sbf question
darkcyber
Android Expert
What version of RSD Lite can be used to do the .602 sbf? The link to 5.4.4 in the sticky thread doesn't work. I didn't know if 4.8 or 4.9 would work or not.
4.9 seems to work on windows xp, windows vista/7 just have issues with rsd lite at times
Ok. I have always used 4.8 for doing sbf back to Froyo on Windows XP. In that sticky thread 5.4.4 is listed. So, I didn't know for sure if it required a newer version of RSD Lite to do the .602 sbf file.
Thanks!
