Hi everybody, can this phone read a SanDisk 64 gb micro SD card class 10?. Do I need to reformat it?. If so, what is the best way to do it?. Do I need a computer to do it?. Thank you for all the help,
Anthony.
The specs say it supports only up to 32gb. I had a 64 in my HTC One m8, then had to buy a new 32gb card for this phone. But I would always suggest getting a class 10. They are much faster loading anything from the phone, and significantly faster when you are putting things to and from a computer
I have used 2 different 64gb SD cards with my zmax. Just put it in the phone while it is still blank and it will say "blank SD card or unsupported file system" and it will ask if you want to format the card. Go ahead and format the card and you will have about 59.5gb free space.
