justinboston
Recently purchased a LG Spirit and love it. I learned from the manual you can add an micro SD card for more memory. I had just bought a 64 Gb for my camera and decided to put it in my LG Spirit phone. Worked great! Tethered it via USB and moved a ton of music and photos to the SD card.
After mounting it in Windows via tethering, was able to create playlists on the card and then drag and drop my music from iTunes into their respective playlists.
Did the same thing with my photo albums.
Then I came here as I had a battery question and read the specs: Upgradeable to 32 Gb Micro SD card. So am I playing with fire by using a 64 Gb card? It's an Sandisk Ultra SD card. Always have used Sandisk or Transcend without issue. Did LG have a software update that allows using 64 Gb cards? Hate to see it all go down the crapper!
