64gb Note 10.1
Grizzly256
Is there likley to be a release of a 64gb Note 10.1 in australia in the next few months of 2013. If not i'll just buy a 32gb 3G one now.
Why pay so much for extra internal 32GB is you can put in a 32GB card for a few dollars?
I doubt they will release 64GB, ever.
I bet because of the extra cost of the 32gb, many are sold in the 16gb forum. I hardly think a 64gb unit will ever be offered.
That was the basic route that I took. Bought the 16GB version and added a 64GB card. Works perfectly and for a lot less.
Is anyone formatting their new cards first, or using them straight out of the packaging.
What format should they be in please?
I have a 32gb sandisk ultra in mine but not used it yet.
Thanks
Graham
Thanks
Graham
I had to use a Motorola phone to format my 64GB card before the Note would recognize it. It should be formatted in FAT32.
Thanks
Graham
I had to format mine using my S2 for some reason no matter what way I tried it was not seen my the note 10.1 untill I did it that way
I really don't understand why they don't make it more easy to upgrade the ram on these devices. Whatever you have, 16/32/64 there always comes a point where you need more.
16/32/64GB is NOT RAM. It is internal memory.
Is MicroSD slot not enough an upgrade for you?
