I am following verygreen's procedure to add CM7 to my newly purchased 8 G microSDHC SanDIsk card. I've used Win32DiskImager to write generic-sdcard.img to the card. However after that completes successfully the card now says it is only 115 MB in unused space and I cannot copy CM7 to it.
I've tried re-doing it several times, in a card reader as well as the onboard reader and always get the same result. (I re-formatted the sdhc and it would only format to 115 MB; I had to use 'diskpart' to restore the care to 8 G).
I'm running Windows 7, 64 bit on an HP Pavilion g7 (Core i5). I also tried this with a second, new 8 G microSDHC and got the same results.
I'm not sure what else to try. Any suggestions?
I checked out the first post, then fast-forwarded to the last when I saw how old it was. I found the answer on the last two pages. Took about one minute.
