802.11r
it is not something usually written in the spec
for example a famous iOS device which doesn't have it in the spec, but supports 802.11r
Yes, I can confirm that the S4 does indeed support 802.11r Fast Transition roaming. SGH-I337ZRAATT on 4.3 was test unit.
It also supports single-stream 802.11ac and hotspot using 5GHz... sweet having laptop connecting to phone on 5GHz at 433Mbps!!!
