Root A big soft brick
grass
So I'm pulling my hair out.
I was on 2.2 rooted on my droid x. Attempted to install a replacement for the taskbar. The phone is stuck in a boot loop now.
I've read about 5,000 different pages saying just use RSD. It all starts by saying; plug the phone in, let the computer detect it, install the drivers..
This is where I'm stuck. The only thing I have access to is the recovery console and the big endless loop. So at no point the phone turns on to the point where the PC will detect it as a device. What step am I missing??
I've also attempted to download a 'stock rom' ? and install it as update.zip from recovery and I'm getting a verification failed message.
I had this issue before the phone was bricked as well. As with any update.zip I attempted to apply I would get this message. The file naming was correct "update.zip" on the root of the SD card.
I've done the wipe data/factory reset and wipe cache option a few times as well.
Guess I finally figured this out shortly after posting that.
Needed to manually enter boot loader before PC would detect phone as a device.
Thanks figured it would be simple after that point and not so much.
So now I have the phone in the bootloader. I have rsd lite. I have the .sbf file (VZW_A855_ESD20_QSC6085BP_C_01.3B.01P_SW_UPDATE) after I hit start the phone says "critical error 1337 510b" rsd sits and then fails.
Lost again.. :(
The status lined being returned by RSD is:
Phone[0000]: Error sending RAM download for bootloader. Device API Error: 0xE0030009 Address: 0x80500000 Command: ADDR (0xE0231009; phone connected
I keep finding things pointing me to download 'thegift' as I have done. And I'm not sure if these are two separate processes or what but I'm completely confused now.
Maybe wrong patch file? Do different versions of RSD require different ini files? Or are they all the same?
Maybe the .sbf file is wrong? What should I be looking for, if I'm trying to do 2.2 factory reset?
4.8 doesn't need a patch. I'm pretty sure you have the wrong sbf. The gift is 2.1. You need 2.2. Go to xda developers forum its in the rooted Dx stickies. Make sure its the full system sbf. Think its VZW _2.3.15....... something, something,
I have the ini from RSD 4.7 + Patch I downloaded.
pst_flash.ini contents:
; Copyright 2009-2014 Motorola Inc.
; Last updated: Aug 11, 2009
; Version: FLASH_N_09.39.02I_ZCH45_INT
; General section
; Parameter/s that refer to the general behavior of flash component
; When PST.DLL is being used, it is preferable to turn ON Synchronization(SyncSwitchFlashMode). With Nextest, turn OFF Synchronization
[General]
SerialPacketSize=8192
SyncJump=1
DebugLogEnable=0
ErrorLogEnable=1
SyncSwitchFlashMode=1
FileMRUListSize=4
VirtualMemory=0
;corresponds to value - enum INPUT_BIT_SRC{ IN_INI=0,IN_API=1};
PrecedenceOption=1
[USB_HSPacket]
;Valid format is: bInterfaceProtocol (in hex)= packet size (in decimal)
0xFE = 32768
0xFC = 64512
;ZEUS- An iDEN Chipset and only number is being allocated
; Chipset section
; 1. Add entry for new chipset in the [chipset] section.
; The only valid format is hex.
[Chipset]
WALLY_CHIPSET = 0x00
PATRIOT_CHIPSET = 0x01
NEPTUNE_LT_CHIPSET = 0x02
RAINBOW_CHIPSET = 0x03
MSM5105_CHIPSET = 0x04
MSM5100_CHIPSET = 0x05
OMAP_CHIPSET = 0x06
SIRF_CHIPSET = 0x07
POG_CHIPSET = 0x08
NEPTUNE_LTS_CHIPSET = 0x09
NEPTUNE_ULS_CHIPSET = 0x0A
NEPTUNE_LTX_CHIPSET = 0x0B
NEPTUNE_LTE_CHIPSET = 0x0C
DALHART_CHIPSET = 0x0D
MSM6050_CHIPSET = 0x0E
MSM6100_CHIPSET = 0x0F
MSM6300_CHIPSET = 0x10
OMAP_POG_CHIPSET = 0x11
NEPTUNE_VLT_CHIPSET = 0x12
NEPTUNE_LTE2_CHIPSET= 0x13
ARGON_CHIPSET = 0x14
SCMA11_CHIPSET = 0x15
BULVERDE_CHIPSET = 0x16
MSM6500_CHIPSET = 0x17
MSM6025_CHIPSET = 0x18
NEPTUNE_LTE3_CHIPSET= 0x19
MSM6150_CHIPSET = 0x1A
MSM6550_CHIPSET = 0x1B
ZEUS_CHIPSET = 0x1C
LOCOSTO_CHIPSET = 0x1D
CALYPSO+_CHIPSET = 0x1E
MSM6125_CHIPSET = 0x1F
QSC6010_CHIPSET = 0x20
MSM6800_CHIPSET = 0x21
MSM6280_CHIPSET = 0x22
MSM6571_CHIPSET = 0x23
MSM6575_CHIPSET = 0x24
QSC6055_CHIPSET = 0x25
QSC6075_CHIPSET = 0x26
MSM6246_CHIPSET = 0x27
MSM6290_CHIPSET = 0x28
QSC6240_CHIPSET = 0x29
WRIGLEY_CHIPSET = 0x2A
QSC6085_CHIPSET = 0x2B
MSM7500_CHIPSET = 0x2C
PXA310_CHIPSET = 0x2D
MSM7201A_CHIPSET = 0x2E
MSM7200A_CHIPSET = 0x2F
MSM7627_CHIPSET = 0x30
QSC6270_CHIPSET = 0x31
OMAP3630_CHIPSET = 0x32
; MA sections.
; 2. Add entry for new MA type in the [MA] section.
; Each key in this section has its corresponding section
; that will hold information specific that particular MA
; type. The only valid format is hex.
[MA]
CDMA_TYPE = 0x01
GSM_TYPE = 0x02
TDMA_TYPE = 0x03
UMTS_TYPE = 0x04
CDMA1X_TYPE = 0x05
4G_TYPE = 0x06
TDSCDMA_TYPE = 0x07
[CDMA_TYPE]
ChipSetSection=CDMAChipset
[GSM_TYPE]
ChipSetSection=GSMChipset
[TDMA_TYPE]
ChipSetSection=TDMAChipset
[UMTS_TYPE]
ChipsetSection=UMTSChipset
[CDMA1X_TYPE]
ChipSetSection = CDMA1xChipset
[4G_TYPE]
ChipSetSection = 4GChipset
[TDSCDMA_TYPE]
ChipSetSection = TDSCDMAChipset
; MA specfic Chipset sections.
; For each MA type, there is a chipset section containing
; numerous chipsets.
; 3. Add chipset key in one of the following chipset sections for
; new chipset, per its MA type.
[CDMAChipset]
WALLY_CHIPSET = CDMA Wally,16
OMAP_CHIPSET = CDMA OMAP,0
[GSMChipset]
PATRIOT_CHIPSET = GSM Patriot,16
NEPTUNE_LT_CHIPSET = GSM Neptune LT,16
NEPTUNE_LTS_CHIPSET = GSM Neptune LTS,16
NEPTUNE_ULS_CHIPSET = GSM Neptune ULS,16
NEPTUNE_LTE_CHIPSET = GSM Neptune LTE,16
NEPTUNE_VLT_CHIPSET = GSM Neptune VLT,16
NEPTUNE_LTE2_CHIPSET= GSM Neptune LTE2,16
DALHART_CHIPSET = GSM Dalhart,0
SCMA11_CHIPSET = GSM SCM-A11,56
BULVERDE_CHIPSET = GSM Bulverde,0
LOCOSTO_CHIPSET = GSM LOCOSTO,0
CALYPSO+_CHIPSET = GSM Calypso+,0
OMAP_CHIPSET = GSM OMAP,0
[TDMAChipset]
PATRIOT_CHIPSET = TDMA Partriot,16
[CDMA1xChipset]
MSM5105_CHIPSET = CDMA1x MSM5105,0
MSM5100_CHIPSET = CDMA1x MSM5100,0
MSM6050_CHIPSET = CDMA1x MSM6050,0
MSM6100_CHIPSET = CDMA1x MSM6100,0
MSM6300_CHIPSET = CDMA1x MSM6300,0
MSM6500_CHIPSET = CDMA1x MSM6500,0
MSM6025_CHIPSET = CDMA1x MSM6025,0
MSM6150_CHIPSET = CDMA1x MSM6150,0
MSM6550_CHIPSET = CDMA1x MSM6550,0
MSM6125_CHIPSET = CDMA1x MSM6125,0
QSC6010_CHIPSET = CDMA1x QSC6010,0
MSM6800_CHIPSET = CDMA1x MSM6800,0
MSM6571_CHIPSET = CDMA1x MSM6571,0
MSM6575_CHIPSET = CDMA1x MSM6575,0
QSC6055_CHIPSET = CDMA1x QSC6055,0
QSC6075_CHIPSET = CDMA1x QSC6075,0
QSC6085_CHIPSET = CDMA1x QSC6085,0
MSM7500_CHIPSET = CDMA1x MSM7500,0
MSM7627_CHIPSET = CDMA1x MSM7627,0
NEPTUNE_LTE2_CHIPSET= CDMA1x Neptune LTE2,16
[UMTSChipset]
OMAP_CHIPSET = UMTS OMAP,0
RAINBOW_CHIPSET = UMTS 3G Rainbow,16
POG_CHIPSET = UMTS POG Rainbow,16
OMAP_POG_CHIPSET = UMTS OMAP POG,0
ARGON_CHIPSET = UMTS ARGON,56
MSM6280_CHIPSET = UMTS MSM6280,0
MSM6246_CHIPSET = UMTS MSM6246,0
WRIGLEY_CHIPSET = UMTS Wrigley,0
MSM6290_CHIPSET = UMTS MSM6290,0
MSM7201A_CHIPSET = UMTS MSM7201A,0
MSM7200A_CHIPSET = UMTS MSM7200A,0
QSC6270_CHIPSET = UMTS QSC6270,0
[TDSCDMAChipset]
PXA310_CHIPSET = TDSCDMA PXA310,0
[4GChipset]
OMAP_CHIPSET = 4G OMAP,0
OMAP3630_CHIPSET=4G OMAP,0
; Flash Parameters section
; The format of keys and values in [flash parameters] section.
; USB Device String Descriptor = Number of Interfaces, Security Model,Flash Control Flags, Platform string
; Blank P2K Wally = 1,0,3, Blank CDMA Wally
; Details on Flash Control Flags is described in Microsoft Excel Spread Sheet FlashParametersWorkSheet.xls.
[Flash Parameters]
Blank CDMA1X MSM5105 = 1,0,0x00000001,Blank CDMA1X MSM5105,0
Blank P2K Patriot = 1,0,0x00000001,Blank Patriot,0
Blank P2K Rainbow = 1,0,0x00000001,Blank Rainbow,0
Blank LCA Neptune = 1,0,0x00000001,Blank Neptune LT,0
Blank ULS Neptune = 1,1,0x00000011,Blank Neptune ULS,0
Blank A920 Paragon = 3,0,0x0000000C,Blank A920,0
Blank Motorola A1000 = 3,0,0x0000000C,Blank A1000,0
Blank Motorola A1010 = 3,0,0x0000000C,Blank A1010,0
Blank FOMA M1000 = 3,0,0x0000000C,Blank M1000,0
Flash P2K Wally = 1,0,0x00000002,CDMA Wally,16
Flash P2K Patriot = 1,0,0x00000002,P2K Patriot,16
Motorola V. NE01 = 1,0,0x00000000,Motorola V. NE01,0
Motorola V.120x = 1,0,0x00000000,Motorola V.120x,0
Flash P2K Rainbow = 1,0,0x00000002,UMTS 3G Rainbow,16
Flash LCA Neptune = 1,0,0x00000002,GSM Neptune LT,16
Flash A920 Paragon = 3,2,0x0000000C,Flash A920,0
Flash Motorola A1000 = 3,2,0x0000000C,Flash A1000,0
Flash Motorola A1010 = 3,2,0x0000000C,Flash A1010,0
Flash FOMA M1000 = 3,2,0x0000000C,Flash M1000,0
Motorola V.120e = 1,0,0x00000000,Motorola V.120e,0
Flash MSM6280 = 1,0,0x00000000,Flash MSM6280,0
Flash MSM6246 = 1,0,0x00000000,Flash MSM6246,0
Flash MSM6290 = 1,0,0x00000000,Flash MSM6290,0
Flash PXA310 = 1,0,0x00000004,Flash PXA310,0
Blank MONAHANS = 1,0,0x00000005,Blank PXA310,16
Flash MSM5100 = 1,0,0x00000000,Flash CDMA1x MSM5100,0
Flash MSM6050 = 1,0,0x00000000,Flash CDMA1X MSM6050,0
Flash MSM6100 = 1,0,0x00000000,Flash CDMA1X MSM6100,0
Flash MSM6300 = 1,0,0x00000000,Flash CDMA1X MSM6300,0
Flash MSM6500 = 1,0,0x00000000,Flash CDMA1X MSM6500,0
Flash MSM6025 = 1,0,0x00000000,Flash CDMA1X MSM6025,0
Flash MSM6150 = 1,0,0x00000000,Flash CDMA1X MSM6150,0
Flash MSM6550 = 1,0,0x00000000,Flash CDMA1X MSM6550,0
Flash MSM6125 = 1,0,0x00000000,Flash CDMA1X MSM6125,0
Flash QSC6010 = 1,0,0x00000000,Flash CDMA1X QSC6010,0
Flash MSM6800 = 1,0,0x00000000,Flash CDMA1X MSM6800,0
Flash MSM6571 = 1,0,0x00000000,Flash CDMA1X MSM6571,0
Flash MSM6575 = 1,0,0x00000000,Flash CDMA1X MSM6575,0
Flash QSC6055 = 1,0,0x00000000,Flash CDMA1X QSC6055,0
Flash QSC6075 = 1,0,0x00000000,Flash CDMA1X QSC6075,0
Flash QSC6085 = 1,0,0x00000000,Flash CDMA1X QSC6085,0
Flash MSM7500 = 1,0,0x00000000,Flash CDMA1X MSM7500,0
Flash MSM7627 = 1,0,0x00000000,Flash CDMA1X MSM7627,0
Motorola Calgary MSM7500 = 1,0,0x00000000,Flash CDMA1X MSM7500,0
Flash MSM7200A = 1,0,0x00000000,Flash UMTS MSM7200A,0
Flash MSM7201A = 1,0,0x00000000,Flash UMTS MSM7201A,0
Flash QSC6270 = 1,0,0x00000000,Flash UMTS QSC6270,0
Morrison = 1,0,0x00000000,Morrison,0
P2K POG = 1,0,0x00000001,Blank POG,0
S Blank Rainbow POG = 1,1,0x00000002,Secure Blank Rainbow POG,16
S Flash Rainbow POG = 1,1,0x00000002,Secure Reflash Rainbow POG,16
Motorola Ezx Bootloader = 2,0,0x00000024,Motorola Reflash Ezx,0
Blank Ezx = 2,0,0x00000024,Motorola Blank Ezx,0
S Blank Neptune LTS = 1,1,0x00000022,Secure Blank Neptune LTS,16
S Flash Neptune LTS = 1,1,0x00000002,Secure Reflash Neptune LTS,16
S Blank Neptune LTE = 1,1,0x00000022,Secure Blank Neptune LTE,16
S Flash Neptune LTE = 1,1,0x00000002,Secure Reflash Neptune LTE,16
S Blank Neptune LTE2 = 1,1,0x00000002,Prod Blank LTE2,16
SE Blank Neptune LTE2 = 1,1,0x00000002,Eng Blank LTE2,16
SE Flash Neptune LTE2 = 1,1,0x00000002,Eng Reflash LTE2,16
S Flash Neptune LTE2 = 1,1,0x00000002,Prod Reflash LTE2,16
S Blank Neptune LTE3 = 1,1,0x00000002,Prod Blank LTE3,16
SE Blank Neptune LTE3 = 1,1,0x00000002,Eng Blank LTE3,16
SE Flash Neptune LTE3 = 1,1,0x00000002,Eng Reflash LTE3,16
S Flash Neptune LTE3 = 1,1,0x00000002,Prod Reflash LTE3,16
S Blank Neptune VLT = 1,1,0x00000002,Secure Blank Neptune VLT,16
SE Blank Neptune VLT = 1,1,0x00000002,Eng Blank Neptune VLT,16
SE Flash Neptune VLT = 1,1,0x00000002,Eng Reflash Neptune VLT,16
S Flash Neptune VLT = 1,1,0x00000002,Secure Reflash Neptune VLT,16
Blank A920 Paragon POG = 3,0,0x0000000C,Blank A920p,0
Blank A925 Paragon = 3,0,0x0000000C,Blank A925,0
Flash A920 Paragon POG = 3,2,0x0000000C,Flash A920p,0
Flash A925 Paragon = 3,2,0x0000000C,Flash A925,0
S Blank Argon = 1,1,0x00000002,Secure Blank Argon,56
SE Blank Argon = 1,1,0x00000002,Eng Blank Argon,56
S Flash Argon = 1,1,0x00000002,Secure Flash Argon,56
SE Flash Argon = 1,1,0x00000002,Eng Flash Argon,56
S Blank SCM-A11 = 1,1,0x00000002,Secure Blank SCM-A11,56
NS Blank SCM-A11 = 1,1,0x00000002,Non-Secure Blank SCM-A11,56
SE Blank SCM-A11 = 1,1,0x00000002,Eng Blank SCM-A11,56
S Flash SCM-A11 = 1,1,0x00000002,Secure Flash SCM-A11,56
SE Flash SCM-A11 = 1,1,0x00000002,Eng Flash SCM-A11,56
S Blank Neptune LTE R3 = 1,1,0x00000002,Prod Blank LTE ROM3,16
SE Blank Neptune LTE R3 = 1,1,0x00000002,Eng Blank LTE ROM3,16
SE Flash Neptune LTE R3 = 1,1,0x00000002,Eng Reflash LTE ROM3,16
S Flash Neptune LTE R3 = 1,1,0x00000002,Prod Reflash LTE ROM3,16
Motopro = 3,0,0x00000005,Intel Blank Motopro,16
NS Flash Motopro = 3,0,0x00000004,Non-Secure Motopro,16
SE Flash Motopro = 3,0,0x00000004,Secure Engineering Motopro,16
BULVERDE = 3,0,0x00000005,Intel Blank Bulverde,16
NS Flash Bulverde = 3,0,0x00000004,Non-Secure Bulverde,16
SE Flash Bulverde = 3,0,0x00000004,Secure Engineering Bulverde,16
S Blank Calypso+ = 1,1,0x00000009,Secure Blank Calypso+,0
NS Blank Calypso+ = 1,1,0x00000009,Non-Secure Blank Calypso+,0
Flash Calypso+ = 1,1,0x00000008,Flash Calypso+,0
S Blank LOCOSTO = 1,1,0x00000209,Secure Blank Locosto,0
NS Blank LOCOSTO = 1,1,0x00000309,Non-Secure Blank Locosto,0
Flash LOCOSTO = 1,1,0x00000208,Flash Locosto,0
NS Flash OMAP = 3,0,0x00000004,Non-Secure Bulverde,16
SE Flash OMAP = 3,0,0x00000004,Secure Engineering Bulverde,16
Blank OMAP24xx = 3,0,0x00000005,Blank Engineering OMAP2420,16
Blank OMAP2430 = 2,0,0x00000005,Blank Engineering OMAP2430,16
Blank NEPTUNE = 1,0,0x00000005,Blank Engineering NEPTUNE,16
Blank OMAP3430 = 1,0,0x00000005,Blank Engineering OMAP3430,16
Blank OMAP3630 = 1,0,0x00000005,Blank Engineering OMAP3630,16
BLANK OMAP750 = 1,0,0x00000005,Blank Engineering OMAP750,16
NS Flash OMAP850 = 1,0,0x00000004,Non-Secure OMAP850,16
S Flash OMAP850 = 1,0,0x00000004,Secure OMAP850,16
WRIGLEY3G = 1,0,0x00000001,Blank Engineering W3G,16
Blank WRIGLEY3G = 1,0,0x00000001,Blank Engineering W3G,16
NS Flash ESPOO = 2,0,0x00000004,Non-Secure ESPOO,16
NS Flash OMAP3430 = 1,0,0x00000004, Non-Secure OMAP3430,16
NS Flash OMAP3430 MI = 2,0,0x00000804, Non-Secure OMAP3430,16
S Flash OMAP3430 = 1,0,0x00000004, Secure OMAP3430,16
S Flash OMAP3430 MI = 1,0,0x00000204, Secure OMAP3430,16
SE Flash OMAP3430 = 1,0,0x00000004, Secure OMAP3430,16
SE Flash OMAP3430 MI = 2,0,0x00000804, Secure Engineering OMAP3430,16
OMAP3430= 1,0,0x00000004, Secure OMAP3430,16
OMAP3460= 1,0,0x00000004, Secure OMAP3430,16
NS Flash OMAP3630 = 1,0,0x00000004, Non-Secure OMAP3630,16
S Flash OMAP3630 = 1,0,0x00000004, Secure OMAP3630,16
SE Flash OMAP3630 = 1,0,0x00000004, Secure Engineering OMAP3630,16
NS Flash OMAP3630 MI = 2,0,0x00000804, Non-Secure OMAP3630,16
;S Flash OMAP3630 MI = 1,0,0x00000204, Secure OMAP3630,16
S Flash OMAP3630 MI = 2,0,0x00000804, Secure OMAP3630,16
SE Flash OMAP3630 MI = 2,0,0x00000804, Secure Engineering OMAP3630,16
NS Flash TI NEPTUNE = 1,0,0x00000004,Non-Secure TI NEPTUNE,16
S Flash TI NEPTUNE = 1,0,0x00000004,Secure TI NEPTUNE,16
Flash AP GW = 2,0,0x00000C04,Non-Secure GreatWall,16
Flash BP GW = 2,0,0x00000C04,Non-Secure GreatWall,16
NS Flash WRIGLEY3G=1,0,0x00000004, Non-Secure WRIGLEY3G,16
S Flash WRIGLEY3G = 1,0,0x00000004, Secure WRIGLEY3G,16
SE Flash WRIGLEY3G = 1,0,0x00000004,Secure Engineering WRIGLEY3G,16
[TI_BLANK_FLASH_FLOW_NO_2ND]
Blank OMAP3430=1
Blank NEPTUNE=1
Blank OMAP750=1
Blank WRIGLEY3G=1
Blank OMAP3630=1
; Boot Command Configuration Section
; The format of keys and values in [BootCommandsCFG] section.
; Command name = Timeout, Number of Overall Retries, Number of Receive Answer Retries,
; Number of Send cmd retries
; CMD_01 = 20,3,5,0
[BootCommandsCFG]
CMD_01 = 5 ,3 ,3 ,0
CMD_02 = 200 ,0 ,3 ,0
CMD_03 = 6 ,3 ,0 ,0
CMD_04 = 600 ,0 ,3 ,0
CMD_05 = 20 ,3 ,3 ,0
CMD_06 = 20 ,0 ,3 ,0
CMD_07 = 20 ,0 ,3 ,0
CMD_08 = 60 ,0 ,3 ,0
CMD_09 = 15 ,0 ,3 ,3
CMD_10 = 60 ,0 ,3 ,0
CMD_11 = 20 ,0 ,3 ,0
CMD_12 = 20 ,0 ,3 ,0
CMD_13 = 15 ,3 ,3 ,0
CMD_14 = 20 ,1 ,3 ,0
CMD_15 = 20 ,0 ,3 ,0
CMD_16 = 20 ,0 ,3 ,0
CMD_17 = 20 ,0 ,3 ,0
CMD_18 = 60 ,0 ,3 ,0
CMD_19 = 60 ,0 ,3 ,0
CMD_20 = 20 ,0 ,3 ,0
CMD_21 = 20 ,0 ,3 ,0
CMD_22 = 20 ,0 ,3 ,0
CMD_23 = 20 ,3 ,3 ,0
CMD_24 = 20 ,0 ,3 ,0
CMD_25 = 20 ,0 ,3 ,0
CMD_26 = 20 ,0 ,3 ,0
CMD_27 = 20 ,0 ,3 ,0
CMD_28 = 20 ,0 ,3 ,0
CMD_29 = 20 ,0 ,3 ,0
CMD_30 = 20 ,0 ,3 ,0
CMD_31 = 20 ,0 ,3 ,0
CMD_32 = 20 ,0 ,3 ,0
CMD_33 = 20 ,0 ,3 ,0
CMD_34 = 6 ,3 ,0 ,0
CMD_35 = 6 ,3 ,0 ,0
CMD_36 = 6 ,1 ,3 ,3
CMD_37 = 6 ,3 ,0 ,0
CMD_38 = 6 ,3 ,0 ,0
CMD_39 = 240 ,0 ,3 ,0
CMD_40 = 6 ,3 ,0 ,0
CMD_41 = 6 ,3 ,0 ,0
CMD_42 = 6 ,3 ,0 ,0
CMD_43 = 6 ,3 ,0 ,0
CMD_44 = 6 ,3 ,0 ,0
CMD_45 = 6 ,3 ,0 ,0
CMD_46 = 20 ,3 ,3 ,0
CMD_47 = 60 ,3 ,3 ,3
CMD_48 = 60 ,3 ,3 ,3
CMD_49 = 120 ,0 ,3 ,0
CMD_50 = 20 ,0 ,1 ,0
CMD_51 = 6 ,3 ,0 ,0
CMD_52 = 6 ,3 ,0 ,0
CMD_53 = 6 ,3 ,0 ,0
CMD_54 = 6 ,3 ,0 ,0
CMD_55 = 6 ,3 ,0 ,0
CMD_56 = 6 ,1 ,3 ,3
CMD_57 = 6 ,3 ,0 ,0
CMD_58 = 6 ,3 ,0 ,0
; Timeout in Secs. The value can be set to >= than 120 secs only.
[RDLENUMTIMEOUT]
; Timeout Value for Q
OMAP = 120
BULVERDE = 120
LOCOSTO = 120
; After downloading RDL, QCOM6246 will reenumerate.(At least for now)
; Specify the wait time for its enumeration in seconds.
Flash MSM6246 = 120
Flash PXA310 = 120
Flash QSC6270 = 120
; In Milliseconds
[WaitTimeCFG]
RDLWaitTimeAfterJump=1000
GSMDWaitTimeAfterRestart=5000
GSMDWaitTimeBeforeFlash=2000
Flash AP GW=1000
Motorola USB Remote NDIS Network Device=240000
;Delay for each Write/Read Operation. Formatted as: Product Name + IOInterval = Delay in Milliseconds
Flash MSM6100 IOInterval=1
; Flashing baud rates (in bps).
; The line is formatted as follows
; Chipset = TIROM default baud, RDL default baud, Desired flashing baud
[FlashBaudrate]
S Blank Calypso+ = 115200, 812500, 812500
NS Blank Calypso+ = 115200, 812500, 812500
Flash Calypso+ = 115200, 812500, 812500
S Blank LOCOSTO = 115200, 115200, 460800
NS Blank LOCOSTO = 115200, 115200, 460800
Flash LOCOSTO = 115200, 115200, 460800
Flash QSC6010 = 0, 115200, 115200
;Mode of RQHSTAT command
[RQHSTAT_MODE]
;0x00000000 // Basic Response
;0x00000001 // Per-Device Response
Mode=0x00000000
[RDLVersion]
;minimum RDL version to enable Locosto Chechsum. The only valid format is hex.
LocostoCSVerify=0x0202
[ZeroRetryRead]
;acceptable Pids, if the device is in the list, it will retry reading when Zeor-Length packets received.
PIDS = PID_41A2,PID_419F
[SendRQUID]
;Need to send RQUID for below device list( 0: NOT Send , 1: Send), default value is 0.
Blank OMAP3430=1
Blank OMAP3460=1
NS Flash OMAP3430=1
NS Flash OMAP3430 MI = 1
SE Flash OMAP3430 MI = 1
NS Flash OMAP3630 =1
NS Flash OMAP3630 MI =1
SE Flash OMAP3630 MI = 1
[SendRQRC]
;If the product string in this list, it will send RQRC to AP interface while in Multi-interface flashing.
NS Flash OMAP3430 MI =1
Thanks I'll give that a shot. I ran into that and started to downloaded it but the download was going really slow (said 2 hours) going faster now. I downloaded the_gift.zip and had no luck. Read that it would have the sbf included and did not. Noticed this one says the_gift2 so it's worth a shot!
haha nicely put. I'm sure before the nights over i'll attempt to brick it again. Only got the phone a few weeks ago, and just got it to the point where it was about what I wanted.. now time to start over! weee!
I had no clue what I was doin when I first bricked mine. I'm such a dumbshit I had to find a computer guy to patch 4.7 for me. Can't learn to fly unless you crash. Now I kindve have a small idea of what I'm doing. Make sure you make a nandroid.... and pass along the kindness when you can. I was lucky enough to have a guy stick with my stupidity for over 12 hours. I can only hope to do the same for someone else someday.
I'm glad that maxim doesn't apply to the airline industry.
Haha...you find someone nerdy enough they'll stick with it just for the self-satisfaction of figuring it out. :D
