A can't get fast web install to work. Help please!
Try turning you Evo off then power on again. I couldn't get past the allow prompt and that seemed to help.
If not...I'd resort to VooDoo.
On your phone, click on AppBrain App, go to "Manage my apps". then click on "Sync with AppBrain" button on the bottom left, then click on the "Perform installs" button just beside it. It should perform all the installs you click on the AppBrain website.... Hope this helps. :)
negative, no luck. mabey its theese work computers but somehow i dout that. im gonna delete my appbrain acct, make a new one, uninstall and reinstall app brain and fast web install and try it when i get home.
what is voodoo?
It was a joke...nm.
Okay before you do all that...log off both on evo and pc then log back on to app brain. Do a power down on Evo restart,see if that helps.
